Custom Tube Mill Line
Тема в разделе 'BlackBerry KEY2 LE', создана пользователем sin57bm, 6 апр 2021.
  1. sin57bm
    sin57bm Пользователь BlackBerry
    sdsd
    The welding tube mill machine is mainly used for the production of longitudinally welded steel pipes. The welding machine effectively solves the internal and external welding forming of the longitudinally welded steel pipe. It adopts an efficient longitudinal welding process and cooperates with the automatic tracking system of the weld. Welding quality provides a reliable guarantee, which can meet various weld inspection requirements for the production of steel pipes.
    Product parameter锛?/strong>
    Brand NameVello
    Voltage380/420/440
    Pipe MaterialStainless Steel
    Pipe shapeRound/Square/Rect
    Useful lifetime40 years
    Welding MachinePlasma
    Place of OriginGuangdong, China
    Applicable IndustrialManufacturing plant
    ModelVL-80
    Horizontal axis diameter锛坢m锛?/td>80
    Vortical axis diameter锛坢m锛?/td>55
    Tube diameter锛坢m锛?/td>桅114-桅168
    Tube thichness(mm)2.0-8.0
    Main motor pawer(kw)17.5x2
    Tube making speed(m/min)0.6-3.0
    After Warranty ServiceVideo technical support, Online support, Spare parts
    Equipment structure:
    The unit of the welding tube mill machine adopts the upper unwinding shaft unwinding, double welding head CO2 fine welding wire welding medium and thick plate butt, super spiral looper, heavy-duty milling machine, cage forming plus four-roller closed hole type, high Frequency welding and automatic control of welding temperature, internal burr removal, internal burr monitoring, automatic tracking of weld heat treatment, four-roll sizing plus Turkish head straightening, milling flying saw, flat-head chamfering by mode, static water of steel pipe body Advanced welding pipe technology and equipment such as compression test, automatic weighing and length measurement of steel pipes, marking, raw materials and welding pipe ends with ultrasonic continuous automatic flaw detection.
    Technical Support:
    The maximum diameter of the steel pipe it produces can reach 25鈥?(蠁630), and the maximum wall thickness can reach 12mm. The equipment can produce in accordance with API SPEC 5L, GB/T 9711-2017, GB/T 13793-92, GB/T 3091-2001 Standard delivery pipes for natural gas, crude oil, refined oil, water, coal slurry, mineral powder and other media, petroleum casing pipes conforming to API SPEC 5CT standards, machinery, chemical industry, and construction conforming to JIS3466, GB/T 6728-2002 standards , Structural steel pipes used in metallurgy, mining, hydropower and other industries.Custom Tube Mill Line
    website:Ссылки скрыты! Войти или зарегистрироваться.
